Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Welder/ing
Old Jan 14, 2010 | 02:12 PM
peow130's Avatar
Just an update for you all: I haven't had the chance to use this thing.
The only 220 setup in our shop is some oldschool plugin with angled plugs.
I need to buy an adapter or re-wire it.
Old Jan 15, 2010 | 10:14 PM
parnelli's Avatar
It is important to preheat the metal before you weld the perch on to prevent cracking as well as to make the weld "stick" but be carefull not to overheat the metal and bend the axle tube when heating or welding and it is not necassary to run a root pass of 6010 or 6011 to achive a full strength weld in this instance, some E7018 AC will do the trick. good luck with the project!
96 DuneRunner
16
Feb 17, 2013 02:24 PM
91 4Runner
Nov 7, 2008 05:24 AM
