Motorcycle lift for removing and installing axles
After fumbling with axles on my floor jack, I looked over in the corner and saw my cheap motorcycle lift from PepBoys and thought I bet that would work great to remove and install an axle. Drug it over, sat the axle on it, and it worked perfect. For the front axle I used a 4x4 under the long side and it just sat there perfect. I think my motorcycle lift will go up to about 18". If I remember right, I payed $50.00 for it on sale a bunch of years ago. Great if you are by yourself.
Later
Later
hmm, good ideas, i need to put a trans in a 84' camaro, may look into picking one of these up, then i can use it on the sas for the mud buggy too!! thanks for the idea yall!!
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
axle, cheap, drop, engine, forums, jack, lift, motorcycle, pdx, remove, removing, transmission, transmissions
