Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Welders for fairly simple bumpers and other armor
Old 12-07-2011, 09:30 AM
YotaRiley's Avatar
I am really new to welding but I want to purchase one that I can do small repairs with and possibly make sliders, bumpers, etc... once I get better at it. Any ideas on generally what kind of welder I should be looking at? I found a craftsman 220v stick welder on craigslist for $100. Would that be sufficient for my needs?
Any advice would be great.
Also, Im on a pretty tight budget...
Thanks
Old 12-07-2011, 09:34 AM
waskillywabbit's Avatar
Lots of info on this subject on this forum section.
:wabbit2:
Old 12-07-2011, 11:29 AM
highonpottery's Avatar
you'll most likely need 220v for anything thick - like armor or welding to frame - stick welder should work well as long as you have the dexterity. a cheap 115v mig will be good for tacking everything or working on whatever doesn't need the extra juice. OR you can just buy a good 220v mig that will do everything.
Old 12-07-2011, 11:47 AM
Swimmerboy2112's Avatar
Highonpottery nailed it, for sheetmetal and thin stuff (up to 1/4") a 115V model is your friend, for anything thicker such as frame or fabrication you will need/want a 230V model.
I HIGHLY suggest going with a Miller or Hobart (rebadged Miller).
I fix plasma cutters and welders for a living so i have some experience in this field.
Go with a Miller Millermatic 180, you won't be disappointed.
Old 12-07-2011, 01:24 PM
wyoming9's Avatar
Wink
Since you are new to welding on a low budget you are between a rock and a hard place .
If you knew how to weld you can always make do with any type of welder just to get the job done .
Those low end stick welders are most often AC only and I would not want to see anyone trying to learn how to strike an arc on one of those frustration levels are very high.
While not every body has the $1000.00 to go buy a new Miller Millermatic 180 I would say try and learn the basics of welding.
look for a lincoln 300 amp ac/dc unit not the best for sheet metal work but it could be done.
06-01-2021 01:51 PM
pplusent
09-18-2018 10:02 PM
jerusry
10-19-2015 05:28 PM
priest16
15
08-06-2015 07:43 AM
skoti89
07-06-2015 07:45 PM
Quick Reply: Welders for fairly simple bumpers and other armor
