Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
changing oil through dip stick
Old Jun 29, 2009 | 07:10 AM
Just Learning's Avatar
i bought one from groits garage, and it works great, the reason is i have a bud built full under carrige skid plate that makes it really hard to change oil
so far im pretty pleased with it- any comments would be appreciated on using this
Old Jun 29, 2009 | 02:30 PM
tc's Avatar
tc
How much of the oil do you think you can suck out?
Old Jun 29, 2009 | 02:48 PM
jpmountainboy's Avatar
i doesnt seem like they get to the VERY bottom of weird shaped ifs pans.
Old Jun 29, 2009 | 03:12 PM
Dan.3's Avatar
why not just drill a hole in the skid plate to access the oil drain plug?? That would seem more efective and easier.
Old Jun 29, 2009 | 03:13 PM
Plumbrbob's Avatar
sweet
Old Jun 29, 2009 | 03:21 PM
tc's Avatar
tc
I don't drop the skid to change mine ... with some creative funnel placement, I can do it without making too big a mess.
Old Jun 29, 2009 | 03:45 PM
xjdubber's Avatar
there is some valves i believe called futomoto that you can thread into the the oil plug hole and then attach a hose too.
Old Jun 29, 2009 | 10:53 PM
scuba's Avatar
There was a thread about those not to long ago, And a few people agreed that they wouldnt trust their engine with a little valve like that..
Old Jun 30, 2009 | 03:48 AM
flashkl's Avatar
I've run a fumoto valve for the last thousand miles or so. No leaks, no problems, except that they are a bit slow to drain. But I'd rather wait a half hour inside my warm house on a cold day while my old oil drains through a tube, past my skids, straight into a container than have it done in five but have to remove little bolts and get all oily...
Old Jun 30, 2009 | 04:02 AM
scuba's Avatar
Panzy
Old Jun 30, 2009 | 04:21 AM
flashkl's Avatar
yeah yeah yeah...
Old Jun 30, 2009 | 04:22 AM
flashkl's Avatar
oh, and might I add that oil on the ground + ponytail = even more of a headache? Perhaps I need to cut my hair...
Old Jul 2, 2009 | 06:42 AM
xjdubber's Avatar
ive seen those futomoto valves and have not ever seen a better made valve than that. they also come with with clips to stop them from opening when they are not supposed. I would deffinetly trust my oil with one of those little valves after all they are made in japan!
Old Jul 2, 2009 | 02:00 PM
surf4runner's Avatar
whAck!!!
thats thinking with yer dipstick, jimmy!
Old Jul 4, 2009 | 07:36 AM
clappedoutyota's Avatar
I trust them on my 05 cummins diesel, those valves are a freakin godsend! when your trying to drain 12quarts of oil and you need to switch oil pans hahah
Old Jul 4, 2009 | 10:50 AM
desertcamper67's Avatar
So how do like the tool? I guess it can work for an auto trans too. Is it quick and does a warm engine help the flow like the traditional way?
Old Jul 7, 2009 | 08:40 PM
wyoming9's Avatar
Talking
I bought one of these air operated ones. We have a Generator that they placed so close to the wall that you can`t get a drain pain in. They had been draining the oil on the floor.
I sucked all the oil out then opened the drain valve to make sure it was all drained out..
Less mess for sure. Like all other it is still best todo any oil change with warm oil.
Jun 1, 2021 01:51 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
the1998sr5
Jul 16, 2015 06:20 AM
HRDC0R19
Jul 5, 2015 06:43 PM
