Product Reviews Post your reviews on automotive and expedition-camping gear here
Cool It
Old May 17, 2005 | 03:40 PM
fireman1525's Avatar
Thumbs up Cool It
Just installed my cool it wrap by Thermo TEch. I saw it advertised to reduce engine temps dramatically. You wrap it onto your header or manifold and strap it down with metal straps. it is like fiberglass and graphite and works great. especially since i just recently put my FIPK in. Cooler engine compartment temps means cooler air, which = more horses and better MPG. I can definately tell a difference in both. Got it from alamomotorsports.com
Old May 18, 2005 | 02:05 PM
desert whomper's Avatar
eventually tho the heat build up inside your heades caused by that wrap will cause them to get too hot and crack or warp.
Old May 19, 2005 | 07:55 AM
Probably
Your Are Probably Right, But The Mechanic I Talked To Said That If I Had Aluminum Headers It Might Eventually Cause Problems, But B/c I Have A Cast Manifold Right Now, It Shouldn't Cause Any Harm Due To The Strength Of The Cast. But If It Cracks It Will Give Me A Reason To Order Headers From Lcengineering!
Old May 20, 2005 | 12:33 AM
DudeBud's Avatar
cast cracks easy keep it out of water and you might be ok
kawazx636
Oct 6, 2021 03:03 PM
Redeth005
Jun 28, 2018 08:16 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Matthew Perez
Sep 28, 2015 05:43 PM
carid
Vendor Advertising
Sep 10, 2015 06:11 AM
