Yet another 2nd Gen CB install. With Pics.
I got a good deal on a Uniden CB radio. It's apretty basic model, but it fits the spot I wanted it perfectly.
I was inspired by Slee offroads install putting the CB into the ash tray location.
This was a little more involved than putting it in an 80 series.
I removed the ash tray, and ash tray slides, and then removed the lower console trim.
I cut out the center console trim so that the CB would slide in all the way. However, I found a problem.
I found the amplifier for the stero system sitting behind the ash tray location.
This made it so the CB wouldn't sit flush with the console trim piece.
With a little poking and prodding, I figured I could move the amp behind the cubby hole that sits under the stock stereo.
With the amp moved, the CB sat flush with the trim piece, however the cable that I was using interfered with the heater duct. Following the directions on Slee Offroad, I removed the CB's antenna connector from the radio, and soldered the antenna cable in.
It's pretty much a slip fit, with tension from the lower lip, but since I plan on driving this truck on some fire roads, I installed teh supplied bracket, and zip tied the bracket to the trim piece. It's in there good and solid.
Here are a few pics of the 4Runner and the CB installed (sorry, I didn't get any in progress pics).
The Antenna is mounted to the rear tire carrier tube (it's not too clear in the pic). During testing, I found that the signal was more than adequate, and I was talking to people several miles away as clearly as CB allows.
some drunk guy
08-03-2021 06:09 PM
runnermedic
13
09-21-2015 05:20 PM
reallynotamechanic
09-20-2015 05:40 PM
reallynotamechanic
09-11-2015 11:52 AM
