CB and antenna instally in my 05 Tacoma
Hey all. I don't post too much on yotatech but thought I'd share my CB install with everyone. I had seen this radio installed in the older tacomas and it was a nice fit so I figured I'd try it out on my rig. It took some 'slight' modification to my dash kit (ie: it was a major pain in the ass) but the final result turned out OK. Here's a few pics:
Cobra 18WXSTII radio
Firestik II antenna
Firestik side body mount
This one shows how I made the ground connection behind the tail light. I sanded the area under one of the fender bolts down to bare metal and attatched it to the base using 10 guage wire.
The coax is run along with some other wiring to the front of the bed and enters the cab through a grommet located behind the drivers side storage compartment. From there I ran it under the carpet and up through the center console. It was a tight fit and all 18 feet of the cable got used. Hooked everything up to the swr and after some fine tuning I'm getting 1.1 across the board, so all is well.
Firestik II antenna
Sorry to dig this up again, but I was going to use the firestik sidemount that you used (looks GREAT, BTW), but was on the firestik website and they only recommended that mount for 2'-3' antennas...have you had any problems with yours? It appears to be a 4', no? Thanks for any advice. If anyone else has used this mount I'd love to hear from you..there is a 4Runner out there that gave me the idea but I can't seem to track his thread.
Well I know this is an old thread, but...your install looks real clean, but I would advise againt doing the ground the way you did. Ive never installed a CB before so I guess I dont really know if its possible to ground elsewhere, but it looks like you are asking for rust problems down the road . With having it sanded down to bare metal like that it wont take long, espacially back ther where moisture tends to build up.
agreed if you want a good chassis ground with low resistance you need to sand to bare metal. If you're that worried about rust you can always paint over it after its bolted.
If he leaves it like it is, he will be battling rust real soon.
BeMiceElf
10-10-2015 09:40 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
Poncho0206
07-10-2015 06:21 PM
