Started the bobbing of my bed
Old 01-09-2009, 01:24 AM
YotaT10095's Avatar
I just started the bobbing of my be on my 95 T100. Here are some pics. Ill post more as I get more done.
Attached Thumbnails Started the bobbing of my bed-009.jpg   Started the bobbing of my bed-014.jpg   Started the bobbing of my bed-025.jpg
Old 01-09-2009, 01:26 AM
YotaT10095's Avatar
more pics............
Attached Thumbnails Started the bobbing of my bed-026.jpg   Started the bobbing of my bed-028.jpg   Started the bobbing of my bed-010.jpg
Old 01-09-2009, 01:29 AM
YotaT10095's Avatar
last 3 pics. Ill post more after I weld......
Attached Thumbnails Started the bobbing of my bed-041.jpg   Started the bobbing of my bed-034.jpg   Started the bobbing of my bed-039.jpg
Old 01-09-2009, 01:38 AM
Guest
dport's Avatar
Sweet, man.
Old 01-09-2009, 07:46 AM
stepside trd's Avatar
what did you use to cut it?? Plasma, wheel, sawzall?? Impressively straight cut!
Old 01-09-2009, 07:47 AM
Looks like you took out a whole foot!
Old 01-09-2009, 10:39 AM
YotaT10095's Avatar
I used a sawzaw. I just made sure the tape lines were exactly straight. Once thats done its pretty hard to mess up. I took out 15 inches. O took out this much because that leaves me with around 7 inches of moveiment for the rear shackles for when i replace the springs and do the sas. I should get my welder in the mail today so hopefully I can finish the job and move on to the SAS with a dana 44. I have never welded in my life so everyone wish me luck!!
thanks for the replies.
Old 01-09-2009, 11:09 AM
eighty5yota's Avatar
i just did a 18 inch bob about 3 months ago, when you weld the sheetmetal back together you should have a back plate system so you dont burn through.
seam the top of the bed, and then tack every 6 inches ( blowing on the welds with compressed air the instant your done welding to set them, this helps reduce the warping. then go back and do every 3 inches, then 1.5 then so on and so forth until its all done. take your time, set your welder up right and youll be fine.
MAKE SURE EVERYTHING FITS BEFORE YOU EVEN THINK ABOUT PUSHIN WIRE!.
happy welding
Old 01-09-2009, 01:55 PM
85, quit being stingy and show some pict.'s!! Just curious, would a wet rag work better than comp. air or not advisable? No need to use seam sealer??
Steezy96yota
07-06-2015 10:00 AM
mickyd9990
07-06-2015 09:01 AM
karbin
07-05-2015 11:37 PM
toyoda8488
07-05-2015 10:18 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: Started the bobbing of my bed
