Question about BL and tube bumpers
Ok so i've been looking around for a tube bumper for the front of my tacoma and i really am getting confused. If i was to buy one now and then installed a body lift, what negative effects would this have? Because on most the sites i've looked, it shows the option to buy for if you do/dont have a BL. im lost
If you bought one made for no body lift and then installed the lift, you would have a gap between the bumper and the body.
Brackets can sometimes be made to correct the bumper for the body lift
yes. and i think the gap is pretty ugly. esp on the arb bumpers. that thick upper tube also blocks the headlights when no brackets are used to keep it level to the body
Depending on what you plan on using the vehicle for, body lifts can be a good way to lift your vehicle. You dont have to worry about any driveline angles, or longer shocks and its cheap
Suspension lifts with soft springs can even make your rubbing worse
I believe this nissan has a 2inch body lift but you get the idea of the gap
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
DrZero
18
07-24-2015 11:31 PM
