hydro pump air pump combo?
Old 11-13-2012, 05:20 PM
Dreidel's Avatar
ok so i have a rv2 air compressor that ive slowly been working on to get a new clutch to work since ups so graciously lost the magnet for my compressor anyway i found a rig that has the power steering that i want to put on my truck and i realized that i dont really have the space to put all this and on top of that i have been talking to a local junkyard owner thats been giving me good deals on parts about a hydraulic winch. from what i hear it is easier and better to run a seperate pump for these 1 so you can winch for a while with the engine off and save under hood space.
so basically im wanting to put a motor on a base plate, run two v belts to rv2 compressor and said power steering pump. mostly what i want to know is will a starter motor run these for some time at high rpm to supply flow for both pumps and not use huge amounts of current. probably a stupid question but bear with me here
Old 11-16-2012, 05:42 PM
wyoming9's Avatar
Red face
Define your idea of high rpm?
Some time??
With Hydraulics you need to know what flow rate gpm and pressure to power your device.
I suppose with the correct gear box you could increase the rpm to the high rpm you need.:jessica:
Old 11-16-2012, 06:06 PM
Dreidel's Avatar
i guess in the 2-4000 range i just figured a power steering pump would work great since those winchs are meant to run off a power steering pump
Doug4320
03-24-2018 10:11 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
Michael oaks
07-27-2015 11:47 AM
calderp
07-27-2015 09:58 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: hydro pump air pump combo?
