Advise needed for 305 chevy swap
Hi from UK , again
Done a search but no clear answers for my question . I have bought a chevy 305 small block with a TH350 trans from a chevy c10 . Question is do I fit the chevy to Toyota manual trans using an adaptor bellhousing or do I fit the Th350 with an adaptor to mount the Toyota tranfer box (prefered option as I want auto).
What are the probs with either choice .
Thanks
Rick
Thanks
Rick
Stick with the TH350 auto and a t-case adapter. Even the relatively anemic 305 will grenade a Toyota tranny in time unless you don't use the skinny pedal ever. Seriously, who would ever do that?!?!?!
My present engine is a 4 cylinder 4Y 2.2 petrol engine so any upgrade would be a bonus . The original factory engine was a 3Y 2.0 petrol:cry: .
I also got a set of tubular headers which sweep backwards , I understand these are required or the exhaust fouls steering ?
I think someone posted once that the firewall needs clearence for the distributor ?
These are the things I need to find out before I start to swap the engine out .
Any help appreciated .
depending on what size tires u run, u may want to gear little bit higher than normal since ur only running a 3 speed, i also agree go with the tcase adpater from downey, theyre pretty much the company for chevy swaps in toyotas, they also got motor mounts, etc.
Be careful with the headers you have, many headers for Chevy applications won't work because they don't fit in between Toyota frame rails. Nothing a few measurements won't answer. Rumor has it that 3rd generation ('84-'91?) Camaro/Firebird headers will fit pretty well but I've yet to confirm. I know that any truck headers are a no-go. The firewall may or may not need clearancing for the distributor. The large diameter HEI distributors most definitely will but later model (or aftermarket) small diameter ones may not. I only knocked back the firewall ~¼" so that the plug wire boots weren't pinched against it and so there was a little more vibration room.
Be careful with the headers you have, many headers for Chevy applications won't work because they don't fit in between Toyota frame rails. Nothing a few measurements won't answer. Rumor has it that 3rd generation ('84-'91?) Camaro/Firebird headers will fit pretty well but I've yet to confirm. I know that any truck headers are a no-go. The firewall may or may not need clearancing for the distributor. The large diameter HEI distributors most definitely will but later model (or aftermarket) small diameter ones may not. I only knocked back the firewall ~¼" so that the plug wire boots weren't pinched against it as so there was a little more vibration room.
Thanks for the replies so far , I know feel more sure I want to do this swap .I have now found a TH350 'short tail' trans for sale , would this be better then the standard TH350 with the long tail shaft for the adaptor or does it not matter . As I need to ship the adaptor kit over form USA to UK costs are needed to be a minimum to keep this swap possible .
Also the guy told me the TH350 has an electric kick down and he gave me a switch that he took off the gas pedal for me to fit on the Runner ? I have seen cables on ebay stating they are for kick down . So is it electric or cable ?
Thanks again
Rick
Thanks again
Rick
Thanks again
Rick
Thanks again
Rick
Also, AFAIK, no TH350's had an electric kickdown, they were mechanical and attached to the carb/EFI linkage. TH700R4's came with electric kickdowns.
The TH350 must have no tailshaft housing at all. You need to have the 4WD variant with no tailshaft housing and a very short output shaft. You can convert any TH350 variant to the 4WD variant by swapping out the output shaft.
I may buy the other TH350 advertised which has the short tail and says was out of a 4 wheel drive . It does look the same as the one I already got , but these units are not common here so 2 may be worth having .
Again , thanks for your advises , I would be so lost with out this site and you guys to help .
Do I need to do a body lift to help clearence ? I have a solid axle and a 3" sus lift .
Rick
correct me if im wrong but the electric kick down cables were made for the shifters on the steering column, if ur putting the shifter in the center console area u dont need an electric one, B&M sells shifter kits with the kick down cables. but yes ur C10 came with a th350, k10's were the 4wheel drive models with the np203 t-cases, im not sure though if theres any difference in the output shafts between the 4wd and 2wd. id imagine they would be the same. i do know they had different output shafts on the later models when they came with the 208 t-cases. if u remove the tailshaft housing, it should have a 27 spline shaft that sticks out 7/8"
It has now been confirmed by you guys and a couple of other places that the box is a TH350 M electric lock torque convertor model as used in the c10 it came out of . Now need the wiring diagram and vac hose hook up .
Thanks again .
Thanks again .
I would need to change the valve block to fit the cable type kick down according to someone I spoke to , as I dont have another trans I will use the one I got .
Thanks again
Rick
