Heat Treated Chromoly Heim Joints from Barnes 4wd!
Heat Treated Chromoly Heims
Barnes 4wd is proud to introduce our new line of Heat Treated 4130 Chromoly Heims. We have the small 3/8" all the way up to the 1 1/4". These heims are made of the best materials and the heat treating only makes it better. We have nine different sizes so you can find just the right size for your application.
Chromoly 3/8- 24 X 3/8" Heim
Heat Treated Chromoly 3/8- 24 X 3/8" Heim Joint
Chromoly 1/2- 20 X 1/2" Heim
Heat Treated Chromoly 1/2- 20 X 1/2" Heim Joint
Chromoly 5/8- 18 X 1/2" Heim
Heat Treated Chromoly 5/8- 18 X 1/2" Heim Joint
Chromoly 5/8- 18 X 5/8" Heim
Heat Treated Chromoly 5/8- 18 X 5/8" Heim Joint
Chromoly 3/4- 16 X 5/8" Heim
Heat Treated Chromoly 3/4- 16 X 5/8" Heim Joint
Chromoly 3/4 - 16 X 3/4" Heim
Heat Treated Chromoly 3/4 - 16 X 3/4" Heim Joint
Chromoly 7/8- 14 X 3/4" RH Heim
Heat Treated Chromoly 7/8- 14 X 3/4" Heim Joint
Chromoly 7/8- 14 X 7/8" Heim
Heat Treated Chromoly 7/8- 14 X 7/8" Heim Joint
Chromoly 1 1/4"- 12 X 1" Heim
Heat Treated Chromoly 1 1/4"- 12 X 1" Heim Joint
We also have all the Jams, Threaded Bungs and Misalignment Spacers.
Rod Ends and Hardware
