Safe Recovery Point
Safe Recovery Point
I'm trying to find a good way to mount some sort of hook or shackle to the rear of my 4Runner. I don't have a trailer hitch or aftermarket bumper. All I have are the two stock attach points under the rear welded to the frame.
I took a friend of mine to the Moses Lake sand dunes a few weeks ago to play around. I got a little excited going up one of the dunes and dug myself into some loose sand pretty good. I was goofing around and wound up stuck.
The easiest way for him to pull me out was from the rear but there was no way to attach the recovery strap to both vehicles, since neither one of us had a "hook" style attach point. I eventually just dug myself out a little and drove out under my own power.
Can I get a shackle of some sort to put through the hole in the rear attach points? Or would that be kind of the same as using a tow rope with metal hooks? Anybody have any other ideas?
what you might want to do is get some sort of D ring shackle, and attach that through one of those loops, and through a tow strap
thats what i did when i towed somebody out at the dunes here in cali
put the tow strap in my D ring recovery thingy for my tow hitch, and borrowed a d shackle from a buddy and put it on a front loop
pulled him right out, even in 2wd
Just an FYI- the two "eyeholes" on the back of a 4runner are not meant to be tow-points, they are tie-down points for situations when you've got something strapped to the roof. You run the risk of those breaking right off if you try to tow from that point, and turning the hook from the tow strap into a very dangerous projectile. I would suggest buying another bolt-on tow hook from Toyota- I think you should have one of those mounted on the front and/or install a trailer hitch with shackel reciever. There are also weld-on shackel mounts that I've seen on the web. Get one of those welded on, and run a D-shackel through it. Worst-case scenario is using the strap on the axel, but you run the risk of seriousoly ˟˟˟˟˟˟ up your vehicle.
The Chem grabed the last set of my hangers. I have 1 more but I'm keeping those for myself.
d-ring question
what is the best way to put them on a step bumper? i don't have a place for a reciever or don't have any way of getting them welded. i tried putting them through the trailer ball holes but the pin is too thick? is there another way or are there recovery d-ring shackles that are thiner or with a thiner pin atleast?
matmattmatthew
10
02-09-2021 04:15 PM
zz_denis
09-06-2015 03:43 PM
