PRO Comp Stage 1 Q?
PRO Comp Stage 1 Q?
So i purchased a used pro comp kit for a 1992 pickup off someone on craigslist. He said he was going SAS so he pretty much gave me the whole front end of his truck. Hubs, axles, steering mumble jumpo and what not. He told me all i would need is shocks, brake lines, and all the stuff for the rear. Springs or blocks.
Anyways after looking at it i noticed im missing a bump stop extention.(i can make) And maybe another part. Thats why i made this thread. He gave me one diff drop bracket. Looks like the passenger side. Is there one for the drivers side or.....?
Again i was told this was a Pro Comp Stage 1 kit. I cant find a picture of one installed. And all the pictures of the lifts, well i dont know what im looking for if that makes since.
If this is in the wrong section plz move.
That would be great. My spindle bushings are shot. I'd like a set to have ready to go when I remove current spindles. I assume 92 spindles are the same? What gears are in the ifs 7.5 third member?
The whole thing, spindles and what not. Rusty brake rotors
The diff drop i have i believe it goes .... look down!
This is the one i have no piece for. Im not quite sure how this drops when you lift it. I can make something but i prefer not to.
I believe it has either 410's or 411's. Ive yet to check the wear on the spindles cause i really havent had a reason to. The person i got it from said the truck had under 100k. I was told the front end was off a 1994 if that matters any...
Well the spindle bushings are brass, mine are shot. They pop out press in, so a set to get ready while I drive is good. O down time. PS Can you contact pro comp and get a parts list for that lift?
maybe this will help? http://www.explorerprocomp.com/PDFs/is/57089.pdf it has the parts list with individual part numbers and shows 2 diff drop brackets.
justdifferentials
14
06-11-2017 08:36 PM
myotherrideisayoshi
09-29-2015 05:41 AM
Odin
09-26-2015 06:56 PM
