Mounting CB antennas in door jam
on a 00 taco there isnt anything above the light, those screws -assuming you are talking about the tail light mounting screws- just go into plastic holders that are placed into the sheet metal of the bed.
im talking about on a 95 4runner in between tailgate and the tail light area
and i know you can take tail light off and screw through there and and see where the screw goes, BUT i've seen people mount the door jam mount above the tail light. where do those screws go? is that bad to do?
on my 89 if you take the taillight out you can reach all the way up to the bottom of the side rail. i have mine mounted in between the tailgate and side have no issues. just take out taillight and look or feel behind where you want to mount it. be sure you drill small pilot holes to start and then step up to the size you need for your mounting screws.
I won't put the antenna there. The ground plane (Don't know if that's the name in English) will be the trucks roof, so you'll have half of your antenna wasted...
Best place is front bumper (If you've an aftermarket one) or the roof.
I've my antennas on the front bumper.
David
David
check this one out https://www.yotatech.com/forums/f2/c...w-pics-180012/
I mounted mine like you are questioning. There is no right or wrong place to put the screws just hold up the bracket to it and see where you want to put it.
yeah but what about the body?
are those screws bad for it when you drill them in?
becasue like you did it, you just drilled it in to no mans land it looks like
but if you go lower, you can take the taillight off and see the screws come through
but when you mount it about the tailight
where the poop do the screws go?
Location: Yotatech, because Pirate is too expensive. NorCal.
He has a bracket going in between the tailgate and the body. Dont know how hes got that attached but screws shouldnt be a problem as long as they are strong enough.
It's been on there for a couple of years now.. the screws did not hit anything, it is dead space above the taillight and it works fine. Many tree limbs have been hit by the antenna.. but that is what the antenna spring is for.
If you are so worried about drilling holes through your 4runner then you can always get a magnetic mount and slap it on your roof.
theking11863
03-19-2016 09:36 PM
britishdudes2dr
07-25-2015 06:47 AM
