help with tire size
help with tire size
ok so im getting some fiberglass fenders and 1 inch body lift for my 93 4runner..
and my buddy was will to give me a set of 35 by 12.5 tires
do you guys think the fenders and body lift will give me enough clearance to fit those tires
You cant glass the rear. You mind barely clear up front, with lots of rubbing. I hope you don't plan on driving any thing other than in a straight line. No fenders up frint and sawzall the rear and you're golden.
Your attacking it wrong. What rubs is the body seam. take off your tires and grab a 10lb sledge and go nuts on the foot wells. you will be able to fit 35's with stock fenders. I ran 35's with only cranked t-bars
i was just staring at my truck and thinking my 33s look too small, i could fit 35s if i break the hammer out.
but i think i'll wear these 33s out and save up for some 5.29s and arbs
its ok man we were all new once, take the plastic inner fenderwell out. behind it should be a piece of metal that looks like it was pinched together at the factory, i hammmered this flat on my taco and my 32s didnt rub.
Location: Houston (home), Atlanta (school), Cincinnati (work)
i can't find a picture on a toyota but here's a writeup with pics on a jeep. same idea
http://www.jeepsunlimited.com/forums...d.php?t=913120
note: you don't have to get as detailed with the body filler and sound deadening and stuff if you don't want to. a few whacks with a giant hammer and some paint should be the basics...anything more is added bonus
djpg2000
11-11-2020 04:56 AM
Luvmeye22re
08-04-2015 03:53 PM
coffey50
07-28-2015 10:55 AM
