Aggressive sound for your Tacoma with K&N Air Intake Systems!
FormerVendor
Toyota Tacoma is a powerful truck and if you want it to sound and perform like that K&N Air Intake Systems will help you to achieve it! 77 Series High-Flow Performance Air Intake System and Blackhawk Induction Air Intake Systems are now available for Toyota Tacoma 2016-2017. Let's take a closer look at each of them.
K&N 77 Series High-Flow Performance Air Intake System replaces the factory air box with oversized high-flow K&N performance air filter connected to a premium metal intake tube for unmatched performance.
Features:
- Estimated HorsePower Gain: 5.71 HP @ 4600 RPM.
- Compatible with OEM computer systems
- Available in different finishes
- Replaces factory air box and inlet tube
- Includes: 4 Clamps, 1 Coupler, powder-coated steel brackets
- Installs in 90 minutes or less.
K&NŽ - Toyota Tacoma 2016-2017 77 Series High-Flow Performance Air Intake System
K&N Blackhawk Induction Air Intake System is a a free-flowing mandrel-bent aluminum tube induction system. It also improves fuel efficiency and throttle response, making it one of the most effective upgrades for the money.
Features:
- Estimated HorsePower Gain: 15.57 HP @ 5446 RPM.
- Made From All Black Components
- Installation takes approximately an hour using standard tools
- Creates a powerful engine sound.
K&NŽ - Toyota Tacoma 2016-2017 Blackhawk Induction Air Intake System
With K&N Air Intake System installed on your Toyota Tacoma you get impressive look under the hood, aggressive sound, improved airflow and outstanding filtration. Which one would your choose for your truck?
Features:
Features:
MudMachine88
09-27-2016 07:06 PM
truck lover
09-20-2016 03:51 PM
lorentracy
09-14-2016 11:19 PM
