URD kit installed today
For some reason I can't view the URD page. I looked on the net and came across this.
This item not legal for sale or use on California pollution controlled motor vehicles.
http://www.lingenfelter.com/lingenfe...id=17&pf_id=70
Will I have an issue when it is due for inspection since it is a Cali spec?
You live in NJ. What in the world are you worried about emmission inspection in CA for?
I have no idea why you can not see the URD page. Everyone else can and it is up and working just fine.
If you want one of our stainless bungs, PayPal $8.99 to Sales@URDUSA.com and include all your shipping info. Then after you do that email me at Gadget@GadgetOnline.com and let me know you have done so and I will get one in the mail to you in the morning.
Gadget
Gadget
$8.99 with S&H?
Dunno, just thought it had something to do with something. So, if I don't have to worry bout Cali emissions, can remove one of the cats if I wanted?
I'll get on the paypal order in a bit. Does this come or need a plug like it has on that other page I have in this thread?
I have no clue about most of this stuff, just getting into it.
I take it the bung gets welded in and it's basically a hole to attach things to. Now do I have to plug it after when there is nothing connected?
Sorry for being a PITA
Make sure to take it to a good shop to weld the bung as stainless can be a pain to weld. If your car is Cali spec'd I would just leave it as is....check the laws in your state for modifying the vehicle's emissions system. Some states are very strict and others are more lax about it.....could be an expensive mistake otherwise.
#25
Originally Posted by 4-RUNNIN' FREAK
$8.99 with S&H?
We do not have stainless plugs, yet...
Gadget
#26
Does anybody know where I can bring my 4runner in to have the URD kit installed on my S/C 4runner? Is a Toyota dealer the only choice? What kind of shops know about the 4runner TRD supercharger and its fuel upgrade kit from URD? I am from San Diego, CA. Any help will be appreciated.
#27
Dealer will refuse since it's not Toyota OEM parts. They would probably void the warranty if they saw the parts, if you still have one.
They said they would have to refuse my headers if I had the ceramic or titanium coated since it was not original. Do a search on the net for a speed/performance shop in your area.
#28
Gadget, this should work with your wideband 02 sensor, correct?
I e-mailed them and they said it won't rust, plus the fact that they have a plug for it since I won't have anything in there after the tune.
#30
Thank you. I am going to order it from them so I can get the plug as well. Then I'll get it welded in. Any special location? On the top or side maybe, so condensation does not sit in there and rust my exhaust more.
Where should it be located along the length for easier access? What should I say to them, or will they know? From what I read the O2 sensor needs a certain temp to function properly.
Sorry for being an idiot.
#31
On the stock down pipe for the dual cat trucks, the best place is on the driver's side of the down pipe forward of the first cat. It needs to on the side on a slightly downward angle so you can get the sensor in there and back out. It has to be accessable.
What you do not want is directly on the bottom. Water is a byproduct of combustion and you do not want that running into the sensor as it will crack the ceramic and ruin it.
Gadget
Gadget
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
