TRD Supercharger Garage Install! DIY
Old 04-16-2003, 09:47 AM
snappy's Avatar
My supercharger is in the mail, so I'm looking at an installation sometime next weekend. I've done what homework I can (Gadget, TRD manual), but does the board have any additional advice or tips?
Specifically, what things should I prepare for (specialty tools, parts, gaskets) and what other things should I do @ the same time? Anyone have tips or additions to the TRD instructions to make the process go a little smoother? I'll take great care when handling the MAF sensor -- what other parts are ultra-sensitive?
Thanks for the help, I have a week and a half to prepare.
Old 04-16-2003, 10:21 AM
rimpainter.com's Avatar
Lucky dog.
Old 04-16-2003, 11:37 AM
PhxTRDRunner's Avatar
The manual that comes with it has great directions. Long as you follow that, you will have no problems.
Have fun!
Old 04-16-2003, 11:43 AM
tomstin's Avatar
Plan on 4 hours, I had the most trouble with the A/C and P/S belts, once you figure out how they work, the rest is basic wrenching. The extension for the oil dip stick took a little bending to get that to fit.
Old 04-16-2003, 12:22 PM
SLC Punk's Avatar
I had to buy some vacuum line for my install. What year is yours?
The reason I had to buy more lines is because my Power Steering pump had a vacuum line that went to the stock manifold.
Old 04-16-2003, 02:52 PM
snappy's Avatar
2002 SR5
Sorry -- forgot to mention the details. I've got a 2002. Any particular tricks/difficulties with this year? I see a lot of stuff for the EGR valve (not on this year, right?)..
Old 04-16-2003, 02:55 PM
Sorry to cut in, but I think the EGR "issue" is referring to the header install. Someone correct me if I am wrong.
Exhuast Gas Recirculation
Old 04-16-2003, 05:41 PM
atarinaper's Avatar
you are right my friend
Old 04-16-2003, 07:58 PM
tomus1000's Avatar
Make sure that you do Gadget's "free fmu mod" while you are there.
Good luck with the install. You are well on your way to smiling more often.
Old 04-18-2003, 10:13 PM
snappy's Avatar
thanks for the tips, fellas..
any recommendations on which injectors to go for? i like the idea of the plug-n-play supra injectors. any feedback?
thanks in advance.
Esibnitsud
07-30-2015 08:19 PM
Toyvana
07-29-2015 10:47 PM
anniesball
07-29-2015 11:46 AM
crashburnoveride
07-10-2015 06:39 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: TRD Supercharger Garage Install! DIY
