Tire/Lift Question
Tire/Lift Question
I just purchased the OME 3'' Lift Kit from toytec and was wondering on what size tire i should get... I am leaning towards BFG Mudterrain 285s but dont know if they will rub. Does anyone know if they will?
I'm gonna go out on a limb here... take this solely as advice, and NOT as any type of condemnation at all...
Please, please use the search function of this forum.
There is enough reading to do on this board about lifts and tire sizes to literally put you into a coma. Also, while you are researching lifts and tire sizes and what wheels work with what lifts etc., you may also come across a bunch of other information that you wanted to know.
Understand that I am jumping on here and telling this nicely because as soon as I read your question, I could already see the "board beat-down" comin your way about using the search function.
You will probably find your answer within the first few posts you read after searching.
Good luck.
James
Good luck.
James
TJWilly
07-31-2015 02:05 PM
