S/C tranny saver...
Thanks chris...swerks if you lo9ok at pic that chris put out, you can see the thread on the left side of the 2 nuts....make it so there is little or none on the left side ofthose 2 nuts...on the one circled only...hope it helps
#27
Did you tighten it up all the way?
Chris
P.S. I did notice a difference on my 1998 that I'm selling. You should notice even shifting from park to drive and park to reverse, pretty easily.
Chris
#28
Guest
Posts: n/a
Originally posted by SLC Punk
Anyone else try this yet?
#30
That's awesome man! I can't take the credit for this mod, that's for sure. If you guys ever have any other technical questions, I'm sure John at IPT could help you answer them. He's real knowledgable and the one that told me about this mod when he did my Valve body recalibration. I'm glad you guys like the mod, because I sure did.
Chris
Chris
#31
Hey chris sorry to bugger in on this convo...but how do you installt eh rc injectors? do i take the o rings off the old ones or what?
m confuzzled...i saw a write up but cant find it anymore...
#32
Take it to email at chrisrademacher@fastmail.fm and check out my install page at: www.works-cited.com/supercharger-install.html also for any hints on what to do. Email me too!
Chris
Chris
#33
crud i need to buy new o rings...damnit....i was hoping to get the injectors installed tonight....
do you know the part number for the o rings? I hope the parts dept is open on sats...
#34
You need to buy 12 new injector o-rings. They'll know exactly what you're talking about. You'll transfer over the large rubber grommet and use the new o-rings on the top and bottom of the RC injectors.
Chris
Chris
#35
One more thing: Soak the o-rings and grommets in corn oil before putting them in. This will keep them lubricated long enough to install them.
Chris
Chris
#39
i have an '01 S/C 4Runner, but i do not see this cable that u all are talking about. the only one that resembles anything close to what u are talking about is the idle adjuster. from the pic that was posted earlier, the only cable i see is the 1 in front. i don't have 2. any suggestions?
