Replaceing ECU
There is a trouble tree in the FSM that the dealer should have been following which would have picked that up very quickly.
At least your truck is fixed and the financial pain should ease up a bit.
#25
Yeah all japanese vehicles have fuses if you hook up teh battery wrong, it could never fry the ecu.
domestics? ECU will pop, no fuse from hooking the batt. wrong...
#26
Good grief......I would be way more than PO'd if the dealer missed that!!!
#27
On another note, does anyone know which fuse goes with the radio, power antenna and, clock and dome lights? I replaced the ACC fuse up under the drivers side fuse box but still no go. Is it one of the fuses in the engine bay?
#28
Try the DOME fuse, it's in the engine bay fuse box.
#30
That's the only one I could see common to all of those areas. I can send you a wiring diagram if you want. PM me an email address if you want a copy.
TURBOrunnerNM
07-22-2015 11:01 AM
