Rebuilding aisin hubs
Originally Posted by Cebby
On mine, the big spring inside the hub (#8 in Adam's pic) is a little corroded. I managed to strip most of the corrosion, but the spring isn't a consistent thickness where the corrosion was (it is thinner there, metal eaten away by ?). There is no fear of it breaking cause it isn't THAT bad, but should I replace these? It still has sufficient power to push the innards like it should since it was working before I tore into it.
#25
It had no effect on the operation of the hub. You'll be fine with the original.
FS[PacNorWest]: 1992 4runner - 5VZ swap - Lifted
Swim
9
01-04-2016 10:47 AM
_Nicco_
09-21-2015 03:06 PM
FS[SouthEast]: Aisin factory hubs, cleaned and lubed
carlspeed
08-23-2015 02:59 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
