Question about a starting problem. Battery?
Old 05-26-2006, 05:53 AM
4Runner4Christ's Avatar
The last two days when I went to start my Runner I turn the key and nothing at all happens. I try it one or two more times and it will start like normal. Any ideas what could cause this?
* In the last couple days I have had to jump start another car.
* My battery terminals are clean and the cables are tight.
* The battery is probably 3-4 years old.
Thanks!
Old 05-26-2006, 06:03 AM
Thanks!
Do a search for “starter contacts”. A lot of info here about that.
If you are going to change them yourself it will be $5.00 for parts.
Old 05-26-2006, 11:08 AM
saulgoode's Avatar
The same happened to my 4 runner 3 yrs ago. When I would start my rig in the morning nothing would happen. I would wait a few min and try it again. Took it to a trusted mechanic and turn out the starter contacts had to be replaced. 220.00 to change those out. And this wasn't a stealership either. Knowing what I now know, I will do it myslf next time.
Old 05-26-2006, 11:17 AM
garrett1478's Avatar
definitely contacts... do them yourself, the dealership charged my sister around $300 about a month ago.
Old 05-26-2006, 12:52 PM
TX-BLKRUNNER's Avatar
does it click when you try to start it? mine did that and i finally cralled underneath to look, and the power wire that goes to the starter was loose, there was nothing wrong with the terminal it was just not making good cotact. good luck
Old 05-26-2006, 12:56 PM
No clicks...just silence. I guess I'll need to research a starter contact replacement... Thanks for the tips! I'll also check the wire to the starter...
GreenLion
06-07-2021 10:49 AM
bigblue82
10
07-06-2015 08:27 AM
88Toy
07-04-2015 02:11 PM
aciorba23
06-29-2015 04:18 PM
odonekanobe
06-26-2015 02:27 PM
Quick Reply: Question about a starting problem. Battery?
