Q about Revtek lift and CV angles
After installing the Revtek 3" lift and new Bilsteins, as described in this thread, I still have some concerns about the CV angles.
I did do the diff drop included in the kit, but from what others have mentioned, the CV angles still seem way off. I thought at first that the spring seats were upside-down, but those checked out fine.
Can anybody w/ a 3rd gen, Revtek 3" lift and Bilsteins help me out and check their CVs, and if they are at a better angle than mine, let me know what you did?
My options currently look like, removing the top-out spacer, or weighing down the front w/ ARB bumper + winch.
Here are some pics:
Driver's side:
Pass. side:
Thanks!
Ken
Here are some pics:
Driver's side:
Pass. side:
Thanks!
Ken
Here are some pics:
Driver's side:
Pass. side:
Thanks!
Ken
Here are some pics:
Driver's side:
Pass. side:
Thanks!
Ken
I think they failed due to age and angle change more than just the angle change IMO. Heck the Runners almost 7 years old, got to expect to replace a few things.
I have also considered pulling the top-out spaces too but have currently decided against it, not worth lossing the lift for now. and then the front would look lower than the rear, Well maybe not if you don't replace the rear spacers with OME springs like me. It was always lower even prior to the lift in the rear.(Before any one says saggy springs I just had them replaced on the TSB for free a month before doing the lift
Guess thats why the say 3" front 2 1/2" rear for the Revtek kits.
I also considered getting a bigger spacers for the diff drops but heck its already at the bottom of the rock guard as Toyota calls it. So not sure if that is a good option, Let see if anyone has any better ideas....
Other than frotn bumper and winch... but that does sound like a good idea in the long run.
Edit: just remembered had this pic after the axle replacement at few weeks ago:
http://community.webshots.com/photo/...41764902yDHgsk
Originally Posted by 4route
from what i've seen on other pics around yotatech, your angles look pretty normal for that size lift ...
Originally Posted by WT
I have done the same lift and yes your angles looks like mine too, Mines been on over a year almost 2 and have recently replaced the right side Axle due to boot failure. Last one was replaced last year. $89.00 for a complete axle with lifetime warranty, so if it rips again its goign back for free replacement.
Yeah I have the OEM springs so my rear is less than 3", so I would still be able to remove the top-out spacer w/o causing too much difference between front and rear. It may even level it out better.
I also just thought of spraying the CV boots themselves with some sort of grease/dressing in an attempt to increase their longevity, similar to how tire dressings are supposed to help the surface of a tire from becoming too "flaky". Hmm.. Meguiars on CV boots? Ah well, it's probably a different type of rubber anyway so it may actually hurt instead of help.
CV angles
I still think those CV angles are a bit harsh. I've got OME all around with 882s up front and an ARB/M8000 sitting on the front and my CV angles are really good IMO. EDIT: I have a 1" custom diff drop spacer, stainless steel. I would think eventually you are going to have issues caused by such a harsh angle, but only time will truly tell!
http://www.drawhorn.org/882s.JPG
Good luck!
Good luck!
Wow Brian, that angle of yours looks soo beautiful (no diff drops on that one?)
I'd say if your fins are touching, it's time to lower it abit (maybe 1 fin touching eachother but nothing more I think. The only really way to find out if you went too far is by having broken parts! doh! which will suck on the long run. If you need more height, look into some roger brown body lifts.
Was that at a stealership or some other shop?
OK - dumb question - why would Revtek sell a lift with a diff drop that didn't provide a proper fix? (please don't flame me). You're cv angles look pretty good in my opinion. I've compared my 4Runner to my Tacoma and they are more similar than different. For what its worth.
Fins touching
Originally Posted by waskillywabbit
Fins touching is bad and the CVs are meant to be almost straight across like the angle in my pic attachment. 3" of lift on the front end of an IFS is pushing the limit IMO and you are just asking to blow out a CV, especially if you don't use something like a diff drop to compensate for it. The Revtek and Daystar lifts may be cheaper up front cost, but you are going to pay for them in the long run. Spend the money up front and get some OME and don't worry about your CVs.
Depends
Brian, how many inches of lift does the OME give? Perhaps for those of us who have already spent money on the Revtek, if we remove the top-out spacer, would get us closer to having flatter CV angles.
Jcrawl94
10
10-24-2015 04:34 PM
kirkrunner
07-27-2015 07:59 PM
