overdrive?
Old 07-01-2004, 03:12 PM
984runnerONE's Avatar
overdrive?
how many people uses the overdrive...?..should i keep it off or on and why...?...
Old 07-02-2004, 06:27 PM
johnkay's Avatar
Od
It should explain in the manual or search web.., but Overdrive is used for over a certain speed (80km canadian - i think 50mph US). It is used as the highest gear -5th gear instead of 4th gear (example: at highway speeds and reduces gas consumption), this keeps your RPM's down and uses less torque? instead of making the truck drive harder with it in the next lower gear(4th). Situations where you want to NOT use Overdrive would be going up steep hills, towing, racing? lol, and maybe 4x4ing where u want less shifting and more power & therefore use less gas. In general, just view OD ON as the highest/last gear and when you are at speed where 4th gear isn't sufficient, then use OD. Ex: You wouldn't drive fast for a long time in 1st gear right? So thats when you use OD, after 4 gear is not enough. It's the same as when you drive manual transmission, you will see the RPM's go up and hear the motor whine when it's time to shift, so if you are in 4th and you are going quicker (ex. highway) and you notice this, then you know it's time to shift/use OD. Can someone confirm/correct?
Old 07-02-2004, 07:49 PM
rimpainter.com's Avatar
Leave OD on (engaged) unless you are towing or going up a big hill and need to keep your momentum. Simple as that.
Old 07-02-2004, 07:58 PM
SLC Punk's Avatar
Overdrive keeps the RPM's down at freeway speeds, thus you get better gas mileage.
Keep it on, unless, like Christian said, you are towing or going up a big hill.
Old 07-02-2004, 08:39 PM
...or smoking a ricer
Old 07-02-2004, 08:43 PM
Guest
4RUNR's Avatar
Why is it called over-drive? It's the 4th gear in a 4 speed transmission!
Old 07-02-2004, 10:52 PM
kyle_22r's Avatar
overdrive means it's ratio is greater than 1:1. there's some older american manual trannies that are 4 speeds with OD, as well as 5 speeds without OD
Old 07-02-2004, 11:21 PM
BajaRunner's Avatar
I hardly use the freeway, I am usually driving in stop and go traffic, going up hills and going slow around town. I usually keep my OD off. Only when I do go on the freeway is when I turn it on.
So you guys are saying I would get better gas mileage if I kept it on at all times?
Liadrin
04-25-2022 02:54 PM
chuckross1957
06-28-2019 10:19 PM
crammit442
7
11-29-2017 12:30 PM
rmill05
09-27-2015 01:43 PM
keithporter83
07-24-2015 07:37 AM
Quick Reply: overdrive?
