No Headlights
Old 06-16-2006, 09:37 AM
cimahar's Avatar
No Headlights
More knightmares,,,,,,,,,,no I can't see at Knight,,, I have been working on this for a while and have over $400- invested and still no lights...... I replaced the main fuse box under the dash and about half of the wires and connectors,,, yes one at a time. then I replaced the light switch assembly,, and still no lights,, if I took the old light switch apart the headlights would come on, but if I put the switch back together, out they would go, thats why I bought the switch assembly, but it no workie,,, any ideas GUYS ?????
I don't even want to think what it would cost if I have to take it to the stealership..............HELP<<<<<<<<<i'm drowning here
Old 06-16-2006, 09:45 AM
gpcollen1's Avatar
Maybe just a ground in that system??
Old 06-16-2006, 11:29 AM
bigacuralvr's Avatar
re-wire them.
Old 06-16-2006, 12:52 PM
Bob_98SR5's Avatar
im dizzy after reading your post. :dizzy:
good advice above
Old 06-16-2006, 03:20 PM
cimahar's Avatar
Hello, what closes the relay ??? if I manually close the relay the head lights work, I have checked and can't find an open ground anywhere,,,,,,,,,,,HELP
Old 06-16-2006, 03:23 PM
ebelen1's Avatar
Did you do anything to cause them to go out (e.g., modification) or did they just go out on their own? It may be better to go to the dealer if you've already spent $400 and you can't figure it out.
kawazx636
10-06-2021 03:03 PM
4banginRunner
11-13-2015 05:23 AM
mreagen
10-05-2015 04:27 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: No Headlights
