Knock Sensor Relocation???
Can someone please tell me if I can relocate the knock sensor on an old pre 84 block??? I'm helping put an 84 engine into an 85 but there is no knock sensor on the old block?!?!?! thanks for your time...........TIM
Check out the lc engineering web site. When using forged pistons in a late block one of the unused bolt holes below th oil filter is drilled and tapped to a 12 x 1.25 size for the sensor to compensate for the forged piston extra knocking. Any unused smaller size bolt holes could be drilled and tapped to mount the knock sensor. With cast pistons keep the hole in the mid section of the cylinders, with froged pistons keep it lower.
djohnson13
09-04-2015 12:35 PM
