Inner HUB Gasket?
Old 08-07-2003, 08:39 AM
wynn's Avatar
Question Inner HUB Gasket?
In the writeup of installing Warn manual locking hubs there's no mention of the inner gasket being installed. Is it necessary? The stock ADD hubs had them so I'll be checking on them today (dealership, autozone, prices/availability etc.) but I wasn't 100% sure I needed them as it doesn't mention it like the Aisin conversion does.
"43422-60010 Gasket - this is the gasket between the axle hub and the Aisin hub body."
Thank you very much for your time and input into this site. I wouldn't have been able to perform half the mods i've done without your encouragement (prodding) or support (peer-pressure).
Soon to be a contributing junior member-
-wynn
Old 08-07-2003, 09:09 AM
metal22lica's Avatar
you are talking about the gasket between the actual hub and your rig right? i got it at the dealership. and i wouldnt put the hub on without it. you dont want any water to get in there.
Old 08-07-2003, 09:11 AM
szf2's Avatar
I just put on my Warn hubs yesterday. I got the inner gaskets from the local dealer for like $2 for both. I would reccomend them to help keep dust and dirt out of the hub assembly. Of course, make sure to thoroughly clean the wheel hub flange of all old gasket material.
Old 08-07-2003, 09:32 AM
Guest
oly884's Avatar
I actually just used some of the "great stuff" gasket maker. I love that stuff! Even though it's more expensive right away, it really helps if you plan on taking more stuff off that you have to use gaskets for.
Old 08-07-2003, 10:13 AM
wynn's Avatar
Wink Thanks
I figured I should. Thanks for the confirmation. And the help
-wynn:pat:
Jcrawl94
10
10-24-2015 04:34 PM
carlspeed
08-23-2015 02:59 PM
Steven.m.paulk
07-24-2015 01:44 PM
PlayAwhile
07-20-2015 11:36 AM
Steven.m.paulk
07-13-2015 01:40 PM
Quick Reply: Inner HUB Gasket?
