High amp Alternator? For 3rd gen???
Old 11-01-2005, 05:06 PM
xcmountain80's Avatar
Hello all,
I know some of you have gone with aftermarket alternators or some with a local rebuild. What I want to know is what you liked th ebest and what I should look for. As far as use goes I am installing a auxillery wire setup from Warn so that I can plug my 3000 watt power inverter in the rear of the runner.
Aaron
Old 11-01-2005, 09:09 PM
98LimitedCustomized's Avatar
I have a GM alternator in mine, real easy to do, real cheap. Search for "GM alternator" and you'll find it.... The casing is bigger on the GM's and you can get it much cheaper and higher amperage than a Toy alt. I got 200 amps for $210.
Old 12-15-2005, 02:36 PM
northfacer581's Avatar
how easy was the install of the GM alternator?
when idling, and then i flick on some of my lights, the headlights go a little dimmer, the heat is not as strong....i think its the alternator, cuz i just replaced the battery.
redneck17
10-29-2015 09:09 PM
jerusry
10-19-2015 05:28 PM
93toyoguy
08-02-2015 07:41 PM
80Truck
07-24-2015 03:12 PM
msane99
07-17-2015 10:13 AM
Quick Reply: High amp Alternator? For 3rd gen???
