help with screaming banshi
my belts are screaming, i do not have a belt running to my ac compresser, so i know its not that belt or pully, that leaves power steering pilly etc, how can i tell which pully is bad its almost like a chirping sound that gets louder and fast when you accelrate, could this be the fan cluth water pump or alt, its sounds kinda like the power steering pully, any help this thing is driving me nuts,
If its the belt, throw some used motor oil on them!
DO NOT do that! Check all the belt(s) for like cracks and missing teeth. I would just replace them, they aren't too expensive, maybe $8-12 per. Also, they could just be loose.... If you think its not the belts, I don't know what to say..someone else will pipe in.
Brian Smith
03-07-2003 05:44 AM
