Hard starting, what could it be?
Old 06-23-2003, 04:59 PM
Guest
4RUNR's Avatar
I noticed it takes about 6-7 starter clicks before it goes! Warm, cold, just driven, doesn't matter. I know this isn't right as my other Yotas always started on 1 click with twice as many miles and even after sitting undriven for a week. After the 4Runner is up and running, no complaints, it purrs.
What things should I look at? It's at 79K and always followed Toyota's recommended maintenance schedule.
Old 06-23-2003, 05:02 PM
Los Gatos?'s Avatar
How old is the battery? I'd check the battery, the ground connections, the alternator to battery connection, and the alternator in general for a loose connection.
Old 06-23-2003, 05:45 PM
keisur's Avatar
Re: Hard starting, what could it be?
what year? what engine? etc.. more info needed here.
if it's older maybe the cold start injector?
Old 06-23-2003, 05:59 PM
Guest
4RUNR's Avatar
I should get a sig
It's '99 V6 auto. It cranks very very strong, if I were to bet the battery is pretty new. Given this fact should I still go over all the connections? (if yah will I lose anything when disconnecting battery? Radio codes and such?)
Old 06-23-2003, 06:36 PM
keisur's Avatar
yes. and the alarm will go bat-schidt when you hook it back up so have your key in your hand to hit the disarm button like you have epilepsy. your contacts in the starter may need replacin'. check here for info:
http://4crawler.cruiserpages.com/4x4.../Starter.shtml
Old 06-23-2003, 07:47 PM
AgRunner06's Avatar
What do you mean by "click"?
Old 06-23-2003, 09:04 PM
Replaced your spark plugs recently?
Old 06-25-2003, 02:53 PM
Guest
4RUNR's Avatar
AgRunner06, well you know those clicks a starter makes About 4 per second is my best guess.
denverbikeguy, honestly I have no idea since I just got it, but from what I understood the previous owner took it to the dealer religiously for recommended maintenance. I'd imagine whatever the last recommended spark change was, if I'm at 79k now, then that's how old the sparks would be. I was going to take out a few and look at them but upon opening the hood found it's a major pain to go through removal just to look at them.
I noticed that if I put the key into ON, so all accessories come up, leave it there for few seconds and then crank, then it starts quicker but still not smooth enough as I'd like. Does the fuel pump pressurize the line with ignition in ON before engine starts?
Old 06-25-2003, 03:06 PM
If you are hearing an audible "click" then you need to replace your battery or starter contacts...
Old 06-25-2003, 03:07 PM
its2slo's Avatar
good question, i always do this on my new engine ever since my old engine mysteriously detonated on start up. (hence the new engine).
so am i doing any good giving it a few seconds whith the ignition in the on position before turning it to start? anyone else do this?
Old 06-25-2003, 03:55 PM
turboale's Avatar
I do the wait thing... I used to be able to hear the fuel pump in my volvo very well, and I would always wait til that started and stopped, then would light it up. Now I just wait a couple secs since I can't really hear the fuel pump in the Runner.
Old 06-26-2003, 04:29 PM
Guest
4RUNR's Avatar
Listen to the MP3 of the engine cranking. Does it sound normal? (It’s inside a closed garage so sounds exaggerated due to reverberation)
Old 06-26-2003, 05:19 PM
keisur's Avatar
that's how mine sounds. it turns over a couple of times before it cranks up but sometimes I jump the gun and let go of the key to early (pull to early, hehe) and have to turn the key again to start the thing.
skoti89
07-08-2015 12:05 AM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
coryc85
07-06-2015 04:07 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Hard starting, what could it be?
