Gas Mileage dropped like a rock
It should sound a bit louder than stock. Opening up the intake box (or cutting a hole in it) will create a louder sound at WOT. Also, like he said, I will never use K&N "filters" again.
I haven't really opened up the throtle. I don't really want to waste the gas. I'll have to try it sometime though.
Thanks for the reinforcement Man4God.
#25
out of curiosity, how do you know? we all know BG's44k works very well and it has proof that it does. same with GM top end cleaner. but i have never seen proof that marvel cleans anything.
#26
oiled K&N filters eventually dirty up your intake system bc the oil that you put on the filter does get sucked through and cakes itself in the intake. plus it dirties your MAF sensor. you will see, keep running the K&N.. before too long you will be back here asking about code this and code that and or how to clean the intake system.. i have used K&N's before i know first hand. wont use them ever again.. use paper filters. much cleaner.
#27
oiled filters are best for racing where you tear down the motor all the time,
don't have emissions equipment, and don't worry about engine wear 'cuz you are always replacing rings anyway. all you want is to keep out squirrels
they are no good for a 1996 + FI street vehicle
#28
I heard about this stuff from a guy at Lowe's
You shouldn't need anything but the occassional injector cleaner if you keep things in a good state of tune.
I have a friend with an old Mazda 323 that had a sticking valve. We dumped Marvel's throughout that car it did some good. But that thing was so beat up we could run a stick of butter through the system and it would have made it work better. From what I've heard, Marvel's is automatic tranny fluid. The high level of detergents in auto tranny fluid are what cleans up deposits and such.
17 mpg around town is about what you can expect.
MadCityRich
#29
I wouldn't take car advice from someone at Lowes. That's like asking for home improvement advice from a restaurant waiter.
MadCityRich
MadCityRich
Your also saying that the K&N won't be too bad for my car? I might just have to add some injector cleaner sometime?
#30
If it were my 4Runner, I'd pull the K&N out.
MadCityRich
#31
Just fyi the gas tank guage isn't very accurate...I'll get 100 miles to the first quarter tank of gas then only 50 out of the second quarter so you can't really judge it off of that...and on the K&N filter subject, I've been running one for over two years and no problems, the people that get the build up in their intake must clean it and oil it like they change their oil or put way too much oil on cause I have zero build up on the intake or MAF sensor...
#32
Thanks for the response. I'm glad to know it is at least working for one person.
skoti89
09-11-2015 07:46 AM
Tacoma1313
08-17-2015 05:44 PM
pyramid
07-30-2015 10:05 AM
pyramid
07-29-2015 06:53 AM
