Finally pulled the code
#41
Originally Posted by 99SR5
no im ordering it in a few days. i have to check how many miles i get on a full tank but i know its not good. i think at half a tank im at around 70-80 miles
The only valid way to figure out mileage is to fill the tank (defined as you stop pumping after the pump shuts off by itself), then driving, and filling up again. The amount you fill up with is the only real indicator of how much fuel you used.
#43
ok i just bought gas at 140 miles. i might have gone to 150 but that would have been ballsy
#47
Originally Posted by fireteacher
i have a spare MAF, used..bought it off of ebay and never installed it..50 bucks and its yours
#49
so when i install it do i have to disconnect the battery or take out the EFI fuse or just throw it in.
And, like we've talked about, you can reset the ECU by pulling the EFI fuse or disconnecting the battery. The upside of doing the EFI fuse is that you won't lose your radio presets and the clock will keep time.
Do either one for a minute, then hook it back up and go. Go fill the tank, reset the trip odometer and let use know how things feel the next time you fill up.
#51
ok well i finally installed the sinsor and i gotta say that working on a truck with an a$$ load of mud under it is a pain, but i got it in and i pulled the EFI fuse for 60 seconds and reenstalled that. anything else i should do. i didnt have torque wrench so i just got the nuts on there snug. Is that ok?
#52
Go fill 'er up, then check back after blowing through a tank full.
#53
ok well im worried becuase i have gone about 15 miles and im between full and 3/4 full. is this normal. i disconnected the battery today for at least half an hour to see if the computer didnt reset when i just pulled the fuse
#54
Remember, the fuel gauge SUCKS for figuring out usage. If you want, head to a pump, top it off, and let us know how much you put in. But, a clean reset on an ecu will generally run rich, so it may be okay.
You really just want to see how this complete tank goes.
#56
oh so it will take a while to completly reset. ok ill use up that tank and let you know
#58
yeup. And you want a nice mix of city & highway. The ECU "maps" cover about 100 grid points from idle to high RPM no load (coasting downhill in gear) to low RPM high load (chugging up a hill), etc. You can to show the ECU a lot of variable driving in order for it to learn how to get the air/fuel mixture right across the board.
But that also says that you don't need to go looking for terrain that you don't normally drive. Just drive as you always do, and don't think about it.
See you in 200 miles or so.
#60
(based on 99SR5's comments at: https://www.yotatech.com/forums/f2/random-stall-85409/)
Ummm...
There _is_ a cut off at redline on an auto, it's ignition & not fuel, but it can defnitely show similar symptoms.
Then, given that you're complaining about poor mileage, I've gotta ask... How often do you bounce off of the rev limiter as you drive??
im having somewhat the same problem.. it stalls out when it hits red line? well my problem is the O2 sensor is bad so that might be it.
...it woudnt need the fuel cut off since its an auto since it shifts at red line by itself
crashburnoveride
07-10-2015 06:39 AM
Jnkml
07-06-2015 01:20 PM
