Double Pole Single Throw (DPST) Rocker Switch
I got some of these for wiring up some lights and my compressor. I liked the look of them.
Anyways, I have been having a problem trying to wire them. There are 4 prongs instead of three, and it is is really throwing me off. When the switch is in the "OFF" position, I am getting a short circuit. When it is "ON", everything works accordingly.
My question is, do I need to be running 2 relays with one switch? I was planning on running 2 aux. light relays, but, I don't have it yet... I'd imagine it wouldn't be a problem, but, maybe it is.
Here's the wiring diagram (For a 6 prong (its a DPDT), I only have the bottom 4 prongs)
I've got the low amp hot wire coming in @ 5, and the ground @ 2. (Where my short is, and it makes sense since there is no resistance). And my pos output to the relay is @ 1.
Any ideas on what to do? Sorry, all the switches I've used just had 3 prongs and were straight forward
The schematic for a DPST switch looks as follows:
Each pin represents one of those switch ends, so you have to make sure you're hooking everything up right. do a continuity test and write down which pin is what.
Right, I understand that its basically like two switches held together with one handle...
According to this analogy, you don't really need a ground for the switch, like other 3-prong switches then, correct?
Just a hot in, and hot out to the acc. relay, right?
I don't have a multimeter to do a cont. test, I need to buy one Thanks for the quick reply!
BTW- This is an LED light, so I guess they don't need grounds.. duhh..
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
sorry i can't help with your problem, but just a push to get that meter! good luck
Crap, I still cannot understand this!! What gives? I think I've tried every wire at every position. Maybe I just burned out the switch at this point.. haha.
Figures though, I always seem to screw up simple projects.
rjtrials
08-06-2015 07:25 PM
crashburnoveride
07-10-2015 06:39 AM
