Did the 97 4r limited come with keyless entry?
tried that and it didnt work very well. i extended it from the driver's side up to the dash. and another time, i extended it along the entire length of the vehicle and hooked it up to the diversity antenna...and even that didnt work very well!
bob
bob
Also, yesterday, I stopped at a grocery store to pick up a few things, and came out to unlock the car. As soon as I hit the unlock button, the alarm started going off. I couldn't shut it off. I pressed the unlock button, put the key in the door (locked and unlocked), started the car (which it did, by the way. Thought it had a starter disabling system?), and finally, I had to just pull the fuse to the horn. It was quite embarrassing. I got home and tried my other keyfob, and now it's working with no problems. What a POS.
If it does start honking, get away from the truck and press the top button a few times until the red light stops blinking. Once its stopped, get close (within range) and press it once. That should stop it. Took me a while to figure that one out. I once drove down the street with the horn still honking. hahaha
I think you guys must have a different system than i do. My brain unit is not under the seats, and i don't have a red led on my remote. Im planning on replacing this for a alarm/remote start unit this fall anyways.
#26
For those interested in replacing the Piezo buzzer only (READ: cheap skates not willing to spend $$ on a new system ), I updated the thread Bob_98SR5 posted in this thread with some pics and info on where to get a new Piezo chirper for cheap.
https://www.yotatech.com/forums/show...ighlight=piezo
Many thanks to d0ubledown for the tip on where to get the chirper.
primordialbeast117
12-19-2015 12:23 PM
charlie_fong
09-27-2015 10:06 PM
