Converting Bench Seat to Bucket Seats
Yeah, I have been thinking about this also. Is it possible to do in the back of a 4runner with a benchseat? (not to hijack this dudes topic) I have heard of it being done before, with pick ups and what not. I would imagine it could be done. and to fill the space in the middle you coul djust put a center console in or something to that extent?
Originally Posted by mk2driver
Anyone done this? or have any idea on what is innvolved?
ERIC
ERIC
-Sherwin
ERIC
ERIC
I swapped '88 buckets for my '88 bench and everything bolted right up.
A friend of mine swapped a '95 Taco split bench into his '99 Taco that came with buckets.
Not sure what vehicle the original poster was referring to... For Tacomas:
- For the same year / generation, all seats conform to the same 8-hole mounting scheme. However, separate buckets and 60/40 buckets (they're really bench-like buckets, not bucket-like bench...) use all 8 holes. The single bench (Regular Cab) uses fewer holes (at least in later models).
- In later pickups / Tacos, all 8 hole locations are moulded in the cabin floorpan. To open up the additional holes for buckets, you need to knock / drill out the remaining holes and get additional bolts and nuts.
NOTE: 60/40's can be chopped down into matching sport buckets by an upholstery shop.
NOTE: There's no guarantee of compatibility among different eras / generations, so it's best to stay within-generation.
I had an 87 4wd with bench. I got 2 buckets from a camry I think or something. I had to drill a few holes and then bolt. Pretty simple. It was so much better than the beat up bench that I had. I was quoted 300 buck to repair. Buckets were free. Only drawback was I could only have 2 people in the front.
Badfish740
09-04-2015 04:21 AM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
