Code 0171
Code 0171
So, I'm getting an engine code 0171: system adaptive fuel too lean. And I don't know what that means. I just had my 2000 4runner tuned up, replacing the plugs, wires, and one ignition coil that was bad. Fixed a lot of my issues, but this popped up.
The shop suggested replacing the O2 sensor, and it might fix the code. Not sure that believe that. But it's something else I could do myself.
Any thoughts from the knowledgable forum on a way to fix the code issue? I have Georgia emissions coming up very soon, and it WILL fail if I have any engine codes.
Ok. Still need a little more help please. What I've done. the plugs, replaced the fuel filter. Cleaned the maf. I've not seen any o2 sensor codes. Any other thoughts?
Edit: removed text that shouldn't have been there.
My '99 FSM lists other possible 'trouble areas' that could cause this:
loose air intake hose
fuel line pressure
injector blockage
coolant temp sensor
gas leakage on exhaust system
Not sure what the last one means
fuel line pressure
injector blockage
coolant temp sensor
Take the intake flexible tube off and give the ribs on the bottom side a good inspection. It's tough to get brake cleaner, etc. on the bottom side.
Are all the plug boots on tight? Check all the other electrical connections too.
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
