Clutch Noises
Write-up on how to do it, the spring is the same one that's on mine:
http://www.4runners.org/articles/clutchbush
Bob
Re: Re: Clutch Noises
Originally posted by chiefroqqa
What I don't look forward to is getting halfway into the job and finding I don't have the right tool, can't get something out/off etc...part of the fun I guess, and a good way to build up the tool selection!
Originally posted by Bob
[B] [\B]
[B] [\B]
I too have the squealy clutch and the clutch shop I had it replaced at (Stock one lasted 115,000) has taken it out and replaced the T/O bearing three times now and the clutch fork the last time( all for free) Still squeals like crazy. It is more annoying than anything!
is there a certain reason you took everything out, like taking care of some other things while you were at it or something?
Can you take a pic of your hands so I can see what a GI Joe Kung Fu grip looks like in real life? Seriously, I was more concerned about ripping wires out (you know what I'm talking about) than anything else. My mistake was not doing what you did and removing the driver's seat for more room and leverage.
I removed the evap box (at least thats what I think it is) b/c I didn't have an extension that was able to fit and remove the master cylinder nuts.
Anyways, yes, sounds like you did it much more efficiently than I did, but I think most people wouldnt have the cojones to do it Keisur-style either.
Bob
#25
Originally posted by Bob_98SR5
Keisur,
Bob
Keisur,
Bob
#26
Originally posted by keisur
I was stupid I should have replaced the two white end bushing since I had it apart, they weren't worn but you know. that is something to think about, Chiefrogga, get those two parts too since you'll have the spring out.
Thanks!
#27
#28
I will, I'm gonna go and get the parts on my lunch break. So, your method of replacing that bushing, do you think it's doable for the rest of us? I have kinda big hands, is there room to work in there? Could you give a little more detail on how you did it? What all did you disconnect first? The linkage and the harnesses? When you mentioned pedal slamming, how did this happen? While releasing the spring? Will it screw anything up?
Thanks!
Thanks!
#29
Chief,
If you have big hands, you may need to do what I did---move some stuff outta the way. My hands are normal size but even so, I moved stuff out of the way b/c I was more afraid of damaging things if I didn't move things outta the way.
Read my write up and if you have anymore questions, post or PM me.
Bob
Bob
#30
Chief,
Bob
Chief,
Bob
What all do you have on your site? I noticed its a register site..got more tech articles?
#31
Chief,
Though Keisur's method requires less work, again, I did not want to take the risk of tearing any wires or breaking anything down there. You won't have much room to manuever and working on removing the spring is a bit difficult, esp if you have large hands as you say. Not saying that it can't be done, but for me, the added steps of removing the stuff made it easier (though time consuming).
As for my other articles, they're all in the Tech section. Corey hasn't had time to include the clutch bushing one that I posted here. I just write articles as I do those repairs/mods. My website is about 75% done. Its just a matter of finding the time to finish.
Bob
Bob
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
