changing from 15" to 16" wheels. backspacing question..
i'm currently running 32x11.50x15's on an aftermarket 15" wheel. it works pretty good with the stock suspension but the tires are a pain to balance....so i was considering changing to a 16" wheel and running 265x75x16's. my thinking is that the 265's will balance easier since they are a bit narrower than the 32's. ..my question is what would be the optimal backspacing for such a set up? i don't want the tires to stick way out past the fenders. ..just enough to avoid rubbing. i'm thinking either 4.0 or 4.5 ....but i'm not sure which one
thanks in advance!
thanks in advance!
Yotadawgjr
10
08-23-2015 10:51 AM
