CB Install
CB Install
Hey guys I am looking to install a CB in my runner and was wondering what online retailers you guys had done business with in the past. I have the radio already (Cobra 19) but I will need an antenna, coax, mounting hardware etc. I am also looking for ideas on mounting the antenna. Thanks in advance!
1 Post
I mounted my antenna on the fender on the drivers side, 2' fiberglass. 2' is short but it is the same heigth as my radio antenna, balances things out.
I had to bend the mount to fit between the fender and the hood. I have bought things from http://www.walcottcb.com/ Good prices, good help. I mounted my radio under the dash on the right side of the steering. I am going to move it to the right side of the trans hump. I would like to mount it in the dash under the stereo but I have 12v outlets there (2000 4Runner)
I come up with a neat trick found a cheap CB ant. at a flea market cut a bolt that would screw into it then mated it to am/fm base now when I drag under tree limbs it just lays over
punks_is_4x4
08-21-2015 01:35 PM
Esibnitsud
07-30-2015 08:19 PM
