Axle shaft bearing?
Old 06-05-2011, 10:40 PM
traxxi2003's Avatar
Axle shaft bearing?
Ok, here is another axle bearing question!! Anyway, today I was removing my truck's rear diff, because I'll begetting new gears. When inspecting the rear wheels for any noticeable play I could not notice any play at all. I then removed the brake drums, I found no evidence of any gear oil leak. I once again inspected the axle shaft for any signs of "in &out" or side to side play and once again nothing. But once I had the axle shaft removed, their is some bearing play. Here is a video that will explain better of what I'm talking about. Is this normal? or these bearing are shot?
http://www.youtube.com/watch?v=4UGPxrUL4cA
The axle shaft on the video above is the worse, the other side has some play but barely noticeable.
Old 06-06-2011, 11:27 PM
raydouble's Avatar
How much movement did that translate into at the shaft end?
I remember a slight looseness in the ones I had out.
Old 06-06-2011, 11:47 PM
traxxi2003's Avatar
With the axle shafts installed, no play at all.
Old 06-07-2011, 12:00 AM
traxxi2003's Avatar
With axle shafts in, none.
Old 06-07-2011, 03:35 AM
Potomacduck's Avatar
Don't worry about it. Those bearings can go 400,000 miles easy.
BTW, I replaced mine at 300,000 and the new Koyo bearings which I bought at the dealer had some play in them after I installed them on the axle - just as you described.
A2theK
01-10-2016 10:18 AM
Jcrawl94
10
10-24-2015 04:34 PM
88sasturbotoy
08-11-2015 01:56 AM
ripp96
07-31-2015 11:14 AM
ripp96
07-25-2015 02:32 PM
Quick Reply: Axle shaft bearing?
