Auto trans fluid capacity 5VZFE ?
Old 06-20-2009, 04:20 PM
alotawatts's Avatar
I remember 2001 2WD 5VZFE auto.trans fluid drain/refill as about 1 3/4 qts. Can someone confirm ?
thx
Old 06-20-2009, 04:36 PM
scuba's Avatar
This might help a bit.
Old 06-21-2009, 12:04 PM
eric-the-red's Avatar
thx
All the manuals say around 2 qts but it actually takes 4-5
Old 06-24-2009, 09:45 AM
stir_fry_boy's Avatar
Start at 4 qts and check from there. Wait a few minutes to check after you finish the 4 qts, I mean wait a few minutes before you check the fluid level on the dipstick before you start your runner (should be between COLD ADD and COLD FULL)
When mine was full to capacity before I drained it without removing the pan it took exactly 4.5 qts. I let it drain a while though. I put mine exactly in the middle between ADD HOT and ADD FULL after warming the car up (driving for 20 min).
Eggslinger
06-08-2019 03:32 PM
D.B.T. 87 4x4
07-20-2015 04:51 PM
the1998sr5
07-16-2015 06:20 AM
andrewtexas123
07-14-2015 04:29 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Auto trans fluid capacity 5VZFE ?
