Anyone have 3.42 gear ratio?
This is going to sound weird. I did as you guys said and jacked up the rear end, turned the right rear wheel one full revolution, and watched the driveshaft turn 1 3/4 times. I did it multiple times and kept getting 1 3/4 turns. I'm probably sounding dumb, but this correlates with a 1.75 gear ratio, which does not make sense.
The more times you spin the tire, the less error you introduce (unless you mis-count the rotations).
Doing it this way can leave alot of room for error. Be sure you only jack 1 tire up like rock slide said, and then have someone spin the tire 20 times. Divide the number of drive shaft rotations by 10, and that should be your ratio (divide by 20 for the spins, and multiply by 2 because one tire is fixed).
Chris
#25
By just spinning once, you have to tell the difference between 1.75 turns, or 1.86 (for a 3.72 ratio), or 1.71 turns for a 3.42 ratio. My point was that it is easier to count a couple extra rotations than try to discern a few degrees of rotation. But that's just me.
So how do you interpret the results of your test? What does 1 3/4 turns correspond to?
#27
This is from car-part.com....if you are 2wd this is saying you have 3.73.....
(6 cyl w/ABS), 4x2 (3.73 ratio)
(6 cyl w/ABS), 4x4, 15" whl, 3.91 ratio
(6 cyl w/ABS), 4x4, 15" whl, 4.10 ratio
(6 cyl w/ABS), 4x4, 15" whl, 4.30 ratio
(6 cyl w/ABS), 4x4, 16" whl, 4.10 ratio
(6 cyl w/ABS), 4x4, 16" whl, 4.30 ratio
#28
On a side note...Not all 3rd Gen with Lockers have 4:30 gear ratio if basing on the axle code on the door jamb. This one reads A03A. Mine is Locked with A04A axle code...could it be because this truck has a manual tranny? Explain explain???
http://cgi.ebay.com/ebaymotors/Toyot...fCarsQ5fTrucks
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
