any 3rd gen w/ HID lighting?
any 3rd gen w/ HID lighting? im ordering some toyota ballast and d2r bulbs for ~150 shipped from ebay.
anyone that retrofitted this, plz give me some tip.
ill use the plate that hold the actual h4 bulb to rebase the d2r bulbs to fit teh housing.
I know there are guys on this board who have done so. You might want to do a quick search for HID on 3rd Gens as well. Here's a couple threads on it that I found when searching:
https://www.yotatech.com/forums/show...HID+Conversion
Post some before and after pics when your finished. Good luck!
thanks for the search rock slides, but ive seen that in the past and the bi-xenon not a good idea for me due to time and patience. however having the high-beam is pretty critical sometime and ill just have to live w/ a low-beam.
hey ebelen1,
was his setup similar to mine or what?
ill be sure to give some details abotu it w/ pics.
hey ebelen1,
hey ebelen1,
hey ebelen1,
Yea I have tried the casper shields with the D2R and D2S bulbs and still wasn't happy with light pattern, it still emits some glare. The setup I have now uses E55 Bi-Xenon projectors and Hella Ballast which gives me a clean wide spread pattern with no glare and still have functioning high beams. I can provide some pics of it later if you want.
I've heard guys say the best way to go HID retrofit was w/ Bi-Xenon.
Iceman601, I'd like to see some pics when you get a chance. Maybe some low and high beam shots as well to see the light spread.
I've thought about doing the conversion, but always found another mod to do instead.
i modified the casper shields, still too much glare. need to do some more tweeking. it will glare like mad with no casper shields.the e55 or any other hid projector setup is the only way to do it safely.
thanks for the inputs everyone. i was afraid of the flare, too. i will get a friend of mine to help me tune the lighting.
hey kyleT, can you post up some pic of the light pattern of urs?
whats ur setup?
whats ur setup?
kawazx636
10-06-2021 03:03 PM
some drunk guy
08-03-2021 06:09 PM
39 Thieves
01-06-2017 01:08 PM
clok
11-19-2015 01:09 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
