Aftermarket Radiator Hoses
Old 12-23-2004, 08:14 AM
Legacy 4Runner's Avatar
Help with Radiator Hose
Does anyone have thoughts on using an aftermarket radiator hose? One in specific is a Dayco brand that flexes to accomodate odd curves. I've got an aftermarket radiator and the lower hose outlet is moved two inches from the extreme driver side left. Using the OEM makes it kink slightly and I am afraid that water will not flow correctly. Help me out guys and gals!
Old 12-23-2004, 08:49 AM
Glenn's Avatar
I have used Dayco hoses with no problems for many years. It would be a good idea to avoid kinking the hose as you described. It will weaken the hose, which is not something you want in a radiator hose.
Old 12-23-2004, 08:50 AM
Are you using the Dayco for upper and lower hoses?
Old 12-23-2004, 08:56 AM
Glenn's Avatar
Lower. I haven't had to replace any of the others yet.
the1998sr5
15
07-14-2020 08:35 PM
JaredL
03-28-2016 09:08 PM
80Truck
07-24-2015 03:12 PM
jjrbus
07-19-2015 02:06 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Aftermarket Radiator Hoses
