96 Taco 3.4 auto random engine skip or buck.
Old 03-10-2012, 04:28 PM
Bigblock's Avatar
Annoying and unreliable.Cant figure this 1 out.So heres a list of new parts replaced to try and resolve this.CKP,FP,MAF,CMP,TB and WP just cause I was in there.This is not a misfire.PC cuts fuel to ALL cyl at once.Verified with noid lights.I have 2 codes that are irrelevantO 340 & PO 401.Engine runs great and has power otherwise.This problem happens any time the engine is running.
Thanks Bigblock
Old 03-11-2012, 05:57 PM
Bigblock's Avatar
Also changed the ignitor and checked the plugs.
Old 03-11-2012, 06:30 PM
rworegon's Avatar
Sounds like a wire(s) from the ECU to injectors is shorting out. Also, are all your grounds in the engine bay in good shape and attached?
Old 03-11-2012, 07:06 PM
Bigblock's Avatar
Actually someone added extra ground wires.Along with the factory ones.
Old 03-12-2012, 04:02 PM
Bigblock's Avatar
Its getting worse.Wont idle anymore.Heres a list of whats been done today.Plugs,wires,coil boots,O2 sensor(front),CTS,TPS,cleaned throttle body.Really all thats left is the ECM and wiring harness.I'm not sure a dealer could find this problem.Any thoughts?
Old 03-13-2012, 05:26 AM
Bigblock's Avatar
I finally found the problem.For those of you who were curious about this the cam position sensor wires were crossed.I guess the last village idiot had to replace the connector.
Charecter1
11-06-2023 10:08 AM
MO transplant
04-23-2023 11:58 AM
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 96 Taco 3.4 auto random engine skip or buck.
