88 4runner sr5 won't start when its raining out.
Old 11-04-2003, 04:09 PM
Andyf's Avatar
I wrecked my mustang a few weeks ago so, I needed a car. My brother being the great guy he is loans me his 88 4runner. Mustangs I know like the back of my hand but 3.0 liter OHC toyotas seem to confuse me.
Truck runs like a champ normally, but when it rains hard (like today) it dosen't want to start, or just plain won't. Its getting fuel cause you can smell it out of the tail pipe. It seems to be getting spark. Is this a common prob? Is there a problem with the MAF sensor? Any suggestions would really help. It's not supposed to stop raining for days.....
Old 11-04-2003, 04:13 PM
Guest
oly884's Avatar
Check the distributor cap. It could have a leak in it. If that's the case, get some silicone sealent and seal it up.
Old 11-04-2003, 08:56 PM
carlos4x4sand's Avatar
I had this problem before or similar. When it would rain my truck would start to act like it was miss firing, i checked the cap it was dry, etc. it was all good. Some how i ended up at the ECU i was damp, i opened it up and it was wet some of the circits were being brigged by the water i dryed it up sealed the best i could with silicon and wraped it in a walmart bag and havent had trouble with it since. Oh this would also prevent it from starting sometimes. Hope im able to help u out. Laterz
Old 11-06-2003, 07:53 PM
Andyf's Avatar
Thats a great idea, it would have taken me for ever to think to look there. I don't want to sound stoopid, but where is the ECU mounted? Under the passenger side of the dash? or kickpanel?
Old 11-06-2003, 08:15 PM
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
Passenger side kick panel. May also want to check the grounds as well... when they don't make contact it can do a number on you!
Old 11-06-2003, 11:26 PM
nightsurfride's Avatar
I have seen water travel down wires into boots at the spark plugs grounding the electricity to the engine before it ever has a chance to jump the spark plug gap. Might check there also.
Old 11-07-2003, 09:40 AM
Adam F's Avatar
Mine does the same thing. Also when doing any kind of water crossings offroad, it dies out sometimes, or just stutters really bad.
How would I go about checking the grounds?
Old 11-07-2003, 03:28 PM
02Runner's Avatar
That things junk!! An 88, c'mon. You need to ditch that thing and buy a newer one.
But since you are a YotaTech member, I'll take it off your hands for only $200.00
Seriously though: It does sound like a ground problem.
Doug M.
Old 11-20-2003, 08:23 PM
Andyf's Avatar
thanks again for the suggestions, I ran a bead of silicone around the case of the ECU, and a bead around the dis. cap. Also put some Di-grease one the plug wires.
hard to bielive.... IT HASN'T RAINED SINCE!
oh well, no news is good news I guess.
Old 11-20-2003, 08:30 PM
Dont forget to cover the holes ontop of the ECU.
arlindsay1992
01-23-2024 01:34 PM
aciorba23
06-29-2015 04:18 PM
newzingo
06-24-2015 01:50 PM
Quick Reply: 88 4runner sr5 won't start when its raining out.
