3RD GEN with manual hubs?
I'm assuming that the rear cap is the same as the front cap if u have auto hubs so that prolly wouldn't help. This is just a thought but what if u used the manual cap and somehow cut the emblem out of the auto cap to fit the whole in the manual one just a thought..it might be crap
I thought about cutting a hole around the emblem, but that wouldn't look right.
I'd want something to look professional.
HMMM..........
I may have to get rid of these rims, ARGH!
Get somebody to make ya some 3/8" wheel spacers
Thinking about it, that would luck wierd, don't you think? The front wheels would be sticking out more than the back ones.
#25
check around I know there are places that make custom spacers. I doubt you would notice 3/8 of an inch. Most older solid axle vehicles were off alot farther than that as far as side to side wheel spacing.
#26
Thanks for all your help.
Anyone else have any other advice?
#27
Originally posted by KING
Do they even have some to begin with?
#28
Originally posted by keisur
All Pro has 3/4" ones. http://www.allprooffroad.com/wspacer.html
ONE-HUNDREND-AND-TWENTY DOLLARS WITH NUT AND STUDS??
Or without EIGHTY NINE DOLLARS?? OUCH!!
If I could find 1/2" spacers for that amount, then I'd consider it.
Good lookin' out, by the way.
#29
YIKES!!
YIKES!!
#30
I seen some 1/2"r's somewhere, I'll post them if I can find them again.
#34
Ahh, you know what..... forget it!
I'll have my dad make me some, he was a professional welder.
I'll have him make them out of aluminum, since all the spacers I found were made ouf of aluminum.
#36
Done the search and I can't quite see the wheels on everyone's rig who has done the ORS manual hub conversion?
Do you have to change wheels?
I have the 5 spoke limited wheels?
I might even be willing to leave the center cap off if the Warn hubs will fit?
Otherwise, this will cost more then I first anticipated.:pat:
Thanx for any answers.
:beaver:
:beaver:
#37
steve, on my 2000,4runner i don't have the limited spoke wheels but i do have the factory wheels that came on it and all they did was remove the center cap i can post a close up pic tommorow if that will help!
#39
Senior Member
Originally posted by mertztr
Danny, you mave manual hubs on there?
#40
H-Man,
Thanks a pic would be very helpful!
This way I can get an idea of what the clearance would need to be and if I had it on the stock wheels?
:beaver:
:beaver:
