3rd gen 4runner auto trans replacement
Hey guys, I'm hoping someone could give me some guidance:
I recently bought a 2000 limited 4runner with 125k mile, a solid rust free frame, but a trans leak at the bell housing (verified by cleaning everything off and watching it leak). Figuring it was the torque converter seal, I tore into the truck and got to the front of the trans. When taking out the seal, I damaged the bearing on the front pump, and bought a new one. I had trouble installing the new front pump and it seems like I bent a few of the clutch fingers on the disks that the planetary unit goes into, and the basket itself from the planetary gear unit now looks distorted.
At this point, I'm wondering what my best options are. The basket and torque converter seem to have a little "heat bluing" on them. I'd hate to throw a questionable trans back in the truck. I'm working on a dirt floor and I'd rather do the job right the first time to avoid doing in twice.
Do I get this trans rebuilt?
Do I get a reman?
Any recommended sources?
And finally, since my truck had the multimode, do I need a particular trans model, or will any 3rd get auto trans fit? I know the transfer case is what controls the drive mode, but is the trans different in any way with the multimode system?
Thanks for any help or guidance you can provide!
Do I get a reman?
I've got a transmission and TC out of a 2000 SR5 without multi-mode. Post your transmission part number and I"ll go look and see if it matches.
Without really being able to look it over, I can't really tell you whether or not you need to rebuild / replace it. I would load it up and go show it to a transmission shop.
I took it to a trans shop and they replaced some parts and put it back together for $400. I drove it last night and it seemed good. Hopefully it will stay together.
There were some metal shavings in the fluid. The shop said it looked like a jasper trans. Are shaving normal for a newly broken in trans?
